BlackandYellowBanshee Posted March 15, 2018 Report Posted March 15, 2018 Just seeing if any of you guys can go out to your garage and check the spacing from your sprocket hub to your carrier. Bearings and seals have all 5hrs on them or so. Only reason for my concern is I just rebuilt my motor and got it dyno’d. Started splattering grease on my sprocket hub (have zerk mod on carrier). Is this small gap an issue? Or did I just pack too much grease in the carrier? No unusual movement in carrier and just retorqued axle nut. Sent from my iPhone using Tapatalk Quote
BlackandYellowBanshee Posted March 15, 2018 Author Report Posted March 15, 2018 Alright. Wasn’t sure if the hub should sit flush. Quote
ginger Posted March 15, 2018 Report Posted March 15, 2018 if it sat flush and flex in the axle would cause it to rub, making more issues. you are good to go sir. Quote
