mxturd Posted July 28, 2016 Report Posted July 28, 2016 I just redid my complete Trans and switched to a chariot basket new clutch and modquad cover and lock up. I'm wondering how the actual lockup installs. Is there supposed to be very little play in the lockup fingers, and are they supposed to touch the pressure plate. I'm doing something wrong just not sure where to go from here. Thanks Quote
sleeper06 Posted July 29, 2016 Report Posted July 29, 2016 When installed correctly fingers should tap back n forth freely. Post pics if you can Quote
Bennett131 Posted July 29, 2016 Report Posted July 29, 2016 And yes they will touch the pressure plate. Quote
mxturd Posted July 30, 2016 Author Report Posted July 30, 2016 I got it figured out, I was trying to lay them down and tighten it down instead of holding them up. Thanks guys Quote
sleeper06 Posted July 30, 2016 Report Posted July 30, 2016 To make it easier you can loop a piece of wire through them Quote
