Trick2stroke Posted April 6, 2016 Report Posted April 6, 2016 Parting out my Red Laker 421 Serval. Doesn't get ridden enough to justify the money invested. All wear items (bearings, bushings, seals, chain etc..) were replaced during the build and have less than 5 hr's of ride time. Prices include shipping to the lower 48, unless stated otherwise. PayPal fees will have to be covered by the buyer or gifted payment sent. PayPal is: [email protected] Pics and vid with 18" tire set up and 421 Engine. **Snipers are sold.** Pics of the hipers and holeshots as well as the 28mm carbs and PT Mids on stock engine set up. The parts from the 421 bike. 421 motor, harness - 2900 Sold Ported serval by CamATV here on the forums, blasted and cleaned port matched cases, all new gaskets, bearings, seals, Custom domes by Cam, Trued and welded 4 mil long rod hot rods crank, Max load and TZ bearings, New Weisco pistons, rings, wrist pin bearing, Cam's promod trans, 15T sprocket, modded shift drum bearing, Billet shifter, Mull Eng. shift star, detend arm, and bearing,, Barnett billet 8 plate basket with spring cushions, F.A.S.T fibers and steels, billet pressure plate, HD springs, pancake bearing, straight cut stock ratio gears, Direct Drive Clutch cover, billet dip stick, Chariot Ultra high flow impeller and cover, Billet water pump gear, Chariot Stator cover with bearing support, Billet Mattoon neutral switch cover, Billet kicker (rock solid, no rattle or swinging out), Chariot cool head, V-Force 4 reeds, Billet intake with crossover. Have boots for anything from a 28mm carb to a 40mm, new clutch arm, spring, bearing and seal, as well as push rod and ball, 200wat DC Electrosport stator, brand new complete harness, coil, CDI. Basically every component was replaced new. Very clean, strong engine, not even completely broken in yet. Runs on Pump, 155PSI on each cylinder. Magura Hydraulic clutch - 150 (100 if bought with the engine, I'd recommend it, the HD springs are no joke) Sold 28mm PWK's w/ cable - 250. Sold Elka 19.5” quad rate fronts remote ressy's long braided hoses for option to mount under seat set up for Fb arms, 195# rider - 575 Sold Fireball LT a arms - 475 Sold Chrome LSR Anti-Vibe Steering stem w/ billet 1 1/8 clamp - 150 Sold Flexx Bars - 160 - Sold LED Light Cannons w/ lens covers - 350 Sold AC ProPegs a little tweaked but in good useable shape, good nets, pegs sharp - 150 Sold YFZ Front spindles/hubs/calipers mint, new pads, Galfer wave rotors, braided stainless lines, MC with ASV C6 lever - 200 Sold Elka Dual rate rear - 550 Roll Design -1 swing arm w/ carrier, RK 520 chain included - 600 AC bumper no dents or bends - 75 Red Lakers F&R like new – 500 pickup or meet, shipping additional. PT Mids High temp black, fresh packing, some dents – 300 Durablue X-33 axle, billet hubs, lock nut, billet sprocket hub Honda bolt pattern, 38T sprocket, billet disk hub w/ Galfer wave rotor – 320 Pending Payment Hiper single beadlocks w/ Holeshot XC’s 22/7/10 & 21/11/9, black rings, tires atleast 95% – 750 Sedona Bazooka tires and rolled lip black rims 19/6/10 front and 18/10/8 rear 95% tread - 350 Probably some things I'm missing, as parts get narrowed down I can refine the list. If you have any questions about a specific part or would like more detailed pictures of something specific let me know. As it sits the banshee is still assembled. Quote
465Boss Posted April 6, 2016 Report Posted April 6, 2016 I see now, nice motor, I may would buy some parts if u part it out, Quote
hp2000 Posted April 6, 2016 Report Posted April 6, 2016 Pm sent tricked Sent from my iPhone using Tapatalk Quote
Shee_fast Posted April 6, 2016 Report Posted April 6, 2016 Motor going whole i assume? Sent from my VS810PP using Tapatalk Quote
sick421 Posted April 6, 2016 Report Posted April 6, 2016 Pm sent on stem Sent from my iPhone using Tapatalk Quote
Trick2stroke Posted April 6, 2016 Author Report Posted April 6, 2016 Yeah sorry the Flexx bars went almost the same minute I posted. The motor I would like to keep together. Quote
sick421 Posted April 6, 2016 Report Posted April 6, 2016 Is the lsr stem +2 ? Sent from my iPhone using Tapatalk Quote
dlove1010 Posted April 6, 2016 Report Posted April 6, 2016 Hydraulic clutch still available Sent from my iPhone using Tapatalk Quote
Trick2stroke Posted April 6, 2016 Author Report Posted April 6, 2016 Stem is +1. Hydraulic clutch has a couple people interested in it, pending payment. Quote
slag_350300 Posted April 6, 2016 Report Posted April 6, 2016 Damn I need those lakers right now!!! Man will you take payments lol I don't have the full 500 right this minute for wheeler parts Quote
