EVERYTHING MUST GO! Help me fund new pipes!
All prices do NOT include shipping, shipping is from Canada, will get quote for you.
All parts are in good working condition unless other wise mentioned
My reviews: http://bansheehq.com/forums/index.php?/topic/167431-tdod101/
Let's start out with the best one. Complete Lower half, includes everything you would need, all bearings, gears, hardware, clutch parts, fibres, screws, nuts, springs, flywheel, stator. EVERYTHING! Good stock crank came off running bike, good cases, no chain whack, no cracks or leaks. All new seals and gaskets from Yamaha unused. Build your self a new lower. $400
Another stock set of cases no hardware, what you see is what you get. $150
Chrome pegs, holes for nerf bars, pictured below will trade for stock pegs unmolested.
Chrome west coast nerf bars, webbing is excellent mounting bracket a little bent but other wise worked well for me. $60
Now for the random parts bin. Again, all parts are in good working order, unless otherwise mentioned.
Stock reeds, I never used them, Could be brand new. Appear to be in excellent condition $30
5 Shift forks, will sell all or individually, $10 for the lot.
Hinson clutch cushions unused $5
2 good bearings with full circlips $10/each or $15 for both
2 sets of rod and ball
water pump seal brand new unused $5
Stock clutch pressure plate $15
2 shift arms, one with spring, one with out $10 each or $15 for both
Assortment of jets, mikuni carbs, pm me for what you're looking for.
stock carb boot clamps $5
Cross over tube with one clip, can't find the other one. small nick on top, does not leak. $5
Stock fly wheel, small gouge, should still work fine $20
Chrome brake lever, small nicks will clean up nice. $10
Gears complete $15
Random stuff, make offer
