ninjamaster Posted December 2, 2003 Report Posted December 2, 2003 Hey, I have not hade my banshee that long. This is my first winter with it. I rode it today and got terably stuck in the mud. When I started out it still had the 24:1. I started it and smoke was only comeing out of one pipe (the left). I then mixed some 32:1 yamalube and poured it in. Then changed the plugs to Ngks. I Rode it. I cleaned it up and locked it now its ready to become winterized. I have about a half to a quarter tank. Should I dump stabil (red gas stabilizer) in the tank? How many ounes? Should I then run all the gas out or drainit out? Will running the motor till it runs out be bad? I heard that you than dump yamalube gas mixture "oil only NO gas mixed with it" in both holes where the spark plugs go and then reinsert and tighten the plugs. How much do I put in and do I use the yamalube? Mext do I drain the brake fluids or trans fluid? Do I cover the pipes or air intake hole? I wont drive it in the snow so I wana winterize it. Should I spray anything on the chaine? What kind of chaine lube do you use? I am curently useing wd 40. What kind of chaine does a stock banshee have? I will proally start useing bel ray. Any thing that I forgot? Thanks for you help its apreciated. I Need some gas cans. Next season I will drain the radiator and start useing really good fluid. I will also start useing silkolean mixed with 93 grade pump gas at a 32:1 mixture. I am thinking of getting a 1 gallon gas can, a 3 gallon, and a five gallon. I will use the 5 gallon when I go away with it and will use the 1 gallon to fill up the tank and the 3 gallon as an over flow (for when there is a little left in the 1 gallon and then I can mix some more). I cant find any 1 gallon containers. Everything is 1.7 or 1.3 gallons. Is a ration right with a cap good to use? What kind of funnel filter should I use? Is sears (a hard ware store brand) A good gas can maker? Thanks again, John Quote
wheeleymaster99 Posted December 2, 2003 Report Posted December 2, 2003 i dont think they make cans that hold an excact amount you just need to put 1 or how ever many gallond when at the pump and can tell. and i would just get some good pj1 chain lube around $4 and will last plenty long and i would recmond you get some castor oil cuz i read in another one of your poasts you like to run your shee high that helps at higher rpm you can get all that out of a rockey montain atv if you dont got a catalog get on www.rockymoutainatv.com they have some good prices and 4 winterizeing your shee i dont rally know i dont do anything just every other day or so just go and ststrt it and keep it cleen is what i do hope i helped Quote
ninjamaster Posted December 2, 2003 Author Report Posted December 2, 2003 Do you change your jets? I think if you run it with stock jets it will not mix right. I think it has to be over 30 degrees? Quote
