lcole2653 Posted August 30, 2015 Report Posted August 30, 2015 Nice set of low hour YFZ450 Shocks already modified for Banshee, You will have to slightly trim the upper mount on your bike 200.00 shipped in Cont US 707-498-2653 Quote
fernie2012 Posted August 30, 2015 Report Posted August 30, 2015 Will ya do 175 paypal gifted shipped Sent from my iPhone using Tapatalk Quote
slag_350300 Posted August 30, 2015 Report Posted August 30, 2015 I'm looking to do this to my banshee as well I was just curious what has to be modified on these shocks for them to work? Thanks Quote
sheerider11 Posted August 30, 2015 Report Posted August 30, 2015 Wtf did this really just happen? 1 Quote
Richard Dryden Posted August 30, 2015 Report Posted August 30, 2015 The frame mount needs to be ground back some for shock body clearance. The shock eye on the bottom being aluminum is thicker than a steel Banshee shock needs to be ground back as it hits the a-arm straight below the bolt hole. Just takes a little time and patience. These clear most aftermarket lower a-arms. This mod makes the front higher due to the added shock length. Quote
Richard Dryden Posted August 30, 2015 Report Posted August 30, 2015 lcole2653 had posts in the past looking for stock width lower a arms that were a gull wing style that would put it back to stock height but was unsuccessful. I believe there are 2+1 arms that are made to do just that. Quote
