ClayAiken Posted July 6, 2015 Report Posted July 6, 2015 So I searched around a little bit and only found threads from about 2007 but the carrier I have on my stock swing arm now appears to be 3 pieces I will get pictures in the morning. There is play inbetween the bearing carrier itself and the 2 end brackets. it seems the aluminum is worn and there's no way to fix. I was told it was a durablue axle also not sure if this matters. But what carriers do you guys like for the stock style swinger? . Really trying to avoid getting into a 400$+ roundhouse setup right now. Quote
sheerider11 Posted July 6, 2015 Report Posted July 6, 2015 Just get another stock till you save up for a good round set up. Quote
draggins10 Posted July 6, 2015 Report Posted July 6, 2015 What advantages does a roundhouse carrier have over stock besides easier chain adjustment? Quote
ClayAiken Posted July 6, 2015 Author Report Posted July 6, 2015 So you think I should get one of these http://pages.ebay.com/motors/link/?nav=item.view&id=291504456529&alt=web Quote
hp2000 Posted July 6, 2015 Report Posted July 6, 2015 I have a stock one in decent shape for cheaper than that. Sent from my iPhone using Tapatalk Quote
ClayAiken Posted July 6, 2015 Author Report Posted July 6, 2015 What do you want for it and do I have to change the bearings? Quote
hp2000 Posted July 6, 2015 Report Posted July 6, 2015 What do you want for it and do I have to change the bearings? Bearings look good to me. Pm me Sent from my iPhone using Tapatalk Quote
fastbanshee8 Posted July 6, 2015 Report Posted July 6, 2015 When you put the grease zerk in the carrier, you need to take the inner seal out of the bearing on each side, so the grease can get to the bearings. Quote
tfaith08 Posted July 7, 2015 Report Posted July 7, 2015 I'm about to ditch my stock carrier in a week or so. If you need it, lmk. Quote
