ZILLAKILLA Posted June 16, 2015 Report Posted June 16, 2015 I have gas overflowing from my right carb. Took it apart cleaned it and not better. I think it's might be the plastic piece that the needle seats on and closes the passage and think it's worn out. What is the part called and where can I get them? I might as well change both and how are they taken out? Thanks Quote
tfaith08 Posted June 16, 2015 Report Posted June 16, 2015 That's the float valve. You can get then with a mikuni rebuild kit. Clean the seat with a q-tip and metal polish or toothpaste. Set the float height as per the manual. It also wouldn't hurt to install an inline filter. Sent from my over there. Quote
