I have gas overflowing from my right carb. Took it apart cleaned it and not better. I think it's might be the plastic piece that the needle seats on and closes the passage and think it's worn out. What is the part called and where can I get them? I might as well change both and how are they taken out? Thanks
That's the float valve.
You can get then with a mikuni rebuild kit. Clean the seat with a q-tip and metal polish or toothpaste. Set the float height as per the manual.
It also wouldn't hurt to install an inline filter.
Sent from my over there.
