Trans oil dip stick question
if you want to be safe and have very minimal wear on your clutch and transmission you can run 2 quarts if you want but 1 and a half to 1.6 is recomeneded. Dont worry about blowing the crank seals the transmission and clutch are both vented through a tube on the top case under the rear motor mount. just some more info if you want ;)
