I ran my bike today and the right cylinder isn't firing. I warmed it up and the left exhaust was nice and warm and the right isn't. Also when I revv it up and the RPM's drop the right exhaust isnt letting out any smoke. It idles and smoke comes out. Also I drive it 20 feet and put it in neutral the RPM's rise just a little. The slides are in sync, choke tube is in place. I took the right carb apart a few days ago and cleaned out the jets.
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
Swap leads from left to right
Swap carbs from left to right
Do a leak down test
Just been through similar crap with mine but doing the above should revieal which part is the issue and go from there
Ok. Just curious what ended up being the problem with yours? Im starting to think the reeds. I never looked at them
Edited by ETR174
That is another thing I want to check. I did put new NGK R plugs in about an hour of engine time ago and the carbs weren't synced then so I'd image it was pooring gas on idle because the right was set really low. I'm not sure though. Not much I can do about it tonight but these are just ideas that I can take a look at tomorrow.
