okbeast Posted August 17, 2014 Report Share Posted August 17, 2014 I need one of the pins that the float 'floats' on for a 38mm Lectron carb. Anyone have a spare by chance? Quote Link to comment Share on other sites More sharing options...
camatv Posted August 17, 2014 Report Share Posted August 17, 2014 i think i do i remove them for "special applications... Quote Link to comment Share on other sites More sharing options...
okbeast Posted August 18, 2014 Author Report Share Posted August 18, 2014 i think i do i remove them for "special applications... Gotcha. Well I've got one that the hole is wallered out in the carb and it is loose. Looks like someone cut the end of it trying to get it to stay in and now it's too short. Let me know how much to ship one down to 76036. Quote Link to comment Share on other sites More sharing options...
camatv Posted August 20, 2014 Report Share Posted August 20, 2014 you can just swap to leverfloat style if the pin wont stay in there.. i will look thursday and see if i have one for sure. if i do i'm pretty sure i can mail it to you Quote Link to comment Share on other sites More sharing options...
camatv Posted August 20, 2014 Report Share Posted August 20, 2014 http://www.lectronfuelsystems.com/products/dual_float_assembly.hti have not tried it but i believe they are glued in there... i use a completely differnt float setup in the ones i convert. they are oem floats that i have to modify to fit.. but no pins and no more sticky floats from dragging the sides of bowls... Quote Link to comment Share on other sites More sharing options...
okbeast Posted August 20, 2014 Author Report Share Posted August 20, 2014 http://www.lectronfuelsystems.com/products/dual_float_assembly.hti have not tried it but i believe they are glued in there... i use a completely differnt float setup in the ones i convert. they are oem floats that i have to modify to fit.. but no pins and no more sticky floats from dragging the sides of bowls... Pic no show. But the design does seem flawed. I pulled one float out and it has 1/16" worn in it from the float arm rubbing it. Quote Link to comment Share on other sites More sharing options...
camatv Posted August 20, 2014 Report Share Posted August 20, 2014 its a jacked up design. with billet bowls and the rubbed on floats they will stick a lot.. Quote Link to comment Share on other sites More sharing options...
