Im going to start a thread on my mild drag build.  My budget is not extremely huge so im going with 4 mil hot rod crank on stock cylinders full drag port, vforce v2's, FTZ out of frame pipes, timing plate at +5 and hopefully get my hands on some PWK 39's here pretty soon.  I only get the chance to work on it every once in awhile.  I picked it up in the St Louis area for under $1000 just needed to be put together. For the most part it is all there but of course there are a few things i will be needing. Now after getting a good look through the parts, here is my running list of what ill be needing: (Feel free to let me know if you have any of it forsale)
PWK 39's
65.00 Pistons
Swingarm bolt and nut
3 point a-arm setup
+10 or +12 swingarm stock carrier set up
rear brake disc
pro design 4 mil cut domes
driveline performance lockup
So that is the major parts of my build and i will keep this thread up to date as i work on it.  The only things that are really done so far are the steering stem in place with handle bars and the bottom end complete besides the driveline clutch which will come when i have the funds for it.  I do have the cylinders on right now without pistons so i could get an idea of what the pipes will look like on it.
I'll keep this updated and maybe i can get some parts that you have laying around off your hands.
