I have a 97 timberwolf that has been sitting for a while and won't start unless I spray gas directly in the carb. I cleaned the gas tank and carb and put on a new gas line and it still won't start. Any one have any suggestions?
After you get it started does it runs okay? Once it is running and is warm does it start on its own?
Have you pulled the line off the carb and made sure the fuel is getting to the carb?
