How to adjust PEP Front shocks
swhitey917
I have set of triple rate PEP front shocks on my quad (LTD mass I believe). Not to familiar with working on shocks and I have a muddy race coming up and would like to set my ride height (Preload) a little higher. How do you make this adjustment on these shocks? Thanks.
Only info I can find when searching is referring to the ZPS shock.
The limmtted mass shocks have preload adjustment just like other high quality aftermarket shocks. There should be a collar with a c-clip inside it holding pressure on the top of the upper spring. You will lift your front end off the ground and push down on that collar to compress the spring which will expose the c-clip. Its much easier with 2 ppl.
Got ya, I see it now. Now the issue is I cant compress the spring to expose the c-clip to make the adjustment
