draggins10 Posted May 1, 2014 Report Posted May 1, 2014 I've been trying for 3 hours with a pipe wrench, leverage bar and pb blaster. And it still won't budge. Are there any tricks? Quote
sprinklerman Posted May 1, 2014 Report Posted May 1, 2014 Heat. Mapp gas torch is just enough. Sent from a van down by the river Quote
WINDYCITYJOHN400 Posted May 1, 2014 Report Posted May 1, 2014 Same as always……..hit it with your purse. 1 Quote
Starwriter Posted May 1, 2014 Report Posted May 1, 2014 If you have an air chisel, you can spin it off pretty easy. Of coarse, make sure you're turning it in the correct direction. Righty tighty, lefty loosey. Quote
draggins10 Posted May 1, 2014 Author Report Posted May 1, 2014 Heat. Mapp gas torch is just enough. Sent from a van down by the river I'm gonna try this thanks Quote
Frankthetank Posted May 2, 2014 Report Posted May 2, 2014 I have an 87 banshee that never had the rear axle out and it took myself and another guy with a torch on a huge bench vise to get the two nuts off. Then it took me a large press to press out the dust seal and bearings. It was not fun. My advice would be to remove the rear axle and carrier as one and take it to a machine shop where they have the large tools and torches to remove it. Myself and another guy tried at my house with big tools at first. We were never going to get it loose. I thought about just buying a different axle. Good luck! Quote
