Screecho Posted January 14, 2014 Report Posted January 14, 2014 I'm new to banshees but I started to build one just for riding trails. I had the engine bored out to 65mm and was just wondering what other steps I need to take as far as carb adjustment if I need to upgrade the head to make it run rite after being bored out Quote
sleeper06 Posted January 14, 2014 Report Posted January 14, 2014 If its just bored out with new pistons should be no diffrent from old set up unless your changing pipes air box etc more info will help Quote
Screecho Posted January 14, 2014 Author Report Posted January 14, 2014 Thanks for the response...I got FMF gold series dual exhaust stock air box but have a k&n filter Quote
tdod101 Posted January 14, 2014 Report Posted January 14, 2014 Ditch the air box and get pods, or lose the lid, make sure to rejet though Quote
kedge82 Posted January 14, 2014 Report Posted January 14, 2014 pipes and k&n air filter usually require jets to be bumped up but this something you should do sfter put bck together. check see what you have for jets right now let the ppl know tell us your elevation and we will try to help you out. riding with inapropiate jetting will piss you off after a fresh rebuild Quote
