Went outside to give banshee a kick and hope it started and surprisingly got it to start for a few seconds, kept trying and gets very close to starting and got it going for about a minute and was responding when I would rev it before bogging down. Felt exhaust and both sides are warm so I know both sides are firing now. im guessing maybe going thru the carbs again and goin thru things others have mentioned.
  • 2 weeks later...
the crossover tube is not the choke tube! its the tube that connects both carb boots most ppl put dumb ass boost bottles on they do jack the oem pipe is better my opioning. amother reason could and most likley has to do with your air fuel mixture needle and you pilot jet. what can u tell has been done to your shee? take apart your carbs again see what size your pilot is report back also tell us your elevation and temp you are tryimg to  run it at. need to know open air box no air box oem air box pipes other than stock did previous owner bore it what size pistons u running all these things change what your jets need. and worse of all you run into many ppl who think if they are master mechanics and change jets with little or no idea to what they actully did. wiyh this still do not forget to do leakdown test because attempting to jet is pointless if your engine is not air tight
