BansheeTeam Posted November 24, 2013 Report Posted November 24, 2013 Hey guys i'm just wondering how much PSI should I get when doing a compression check now that I've done a rebuild with an OEM .50 over piston and that the stock head is milled 0.020" I'm also getting a port job and i've heard it'll lower my compression if so by how much? It's mainly just a basic port job (as some people say "cleaning out the holes") What if to balance things out I get a pro design cool head or noss head with lets say 21cc domes or maybe 20cc's if their usable with 95 octane gas. ------------ MODS: OEM .50 over pistons Stock Milled head ( 0.020" ) +4 Timing Advance Toomey T5 V-Force 4 Pod K&N's w/ outer-wears Motion pro T.O.R.S removal kit 15/42 gearing Port job 300 main / 30 pilot / 3rd groove dyno-jet needle ____________ Quote
Sandking Posted November 24, 2013 Report Posted November 24, 2013 That is a question for whoever is doing the porting. Quote
possum Posted November 24, 2013 Report Posted November 24, 2013 "cleaning out the holes" isnt gonna change compression much if at all. Quote
BansheeTeam Posted November 25, 2013 Author Report Posted November 25, 2013 "cleaning out the holes" isnt gonna change compression much if at all. What gains should I get with this method and what if it weren't just "cleaning out the holes" Quote
sprinklerman Posted November 25, 2013 Report Posted November 25, 2013 Wasn't this topic addressed for you in this thread that you started? > http://bansheehq.com/forums/index.php?showtopic=171549#entry1543512 The long and short of it is this > If the "buddy" you have porting your cyls can't answer this for you, why use him? Its obvious they don't know what they are doing or you wouldn't be asking... so why not save your money, and send it to a reputable builder that can answer your questions about the motor? Its going to bite you in the wallet if you don't. Quote
