I have a drag race this saturday and while I was tuning up my banshee all hell broke loose last night.
My lightened flywheel cracked, came apart and toasted my stator....with that known, I snagged a flywheel and stator asap and replaced them....Now I am down to an intermittent / random spark.
The signal to the coil only comes in once or twice when I kick the bike - instead of consistantly throwing a signal. I encountered this once before and found the key switch at fault. This is what I have tried so far....
I have replaced a stator, flywheel. Next I replaced and cut a spare wiring harness to a "race harness" leaving only the lights to be controlled by the handle switch....a pull tether is my kill switch now, no key.
Ive tried a new CDI, still no difference...
what the hell could be causing this horrible signal from my orange ignition wire? I really need advice on this one. Im pulling out my hair
Stator is oem. I just checked the flywheel like u said to do. It didn't look quite right so may have been aftermarket or something like that...I swapped a buddys flywheel over and boom. She got good signal. So I hooked up my coil and started.first kick. Now I need a flywheel by saturday! Thanks for chiming in bud. I appreciate.the fast advice. I was very frustrated and being pressed for time I lost my cool and needed some help
Did you check the pickup coil gap on the flywheel that didn't work? Maybe the gap was too wide.
Thanks hazzard, I would have been greatful nonetheless. I ran one down. Went to race day and won both of my classes! And yes I did. She.was gapped at a tight .020 at the.time.I had tried EVERYTHING, glad I got her all solved and whatnot
  • Like 1
