So im going to be putting my shee back togther in the next couple of days from doing my first top end rebuild an i see everyone talking about having the right slide in the right carb, how do you know which one goes in which
the angled cut out needs to face the airfilter... Look on the slides and about 3/4 the way up the slide on the side you'll see a small hole... That hole needs to line up with/be facing the small clear window on each carb... The holes won't line up with the windows unless it's at wide open throttle... But you'll be able to see where they need to be... Don't forget to re-sync the carbs after you install them completely
