BeeCanBanshee Posted May 20, 2013 Report Posted May 20, 2013 So I my bike won't start...ran fine last time I had it out. I checked stator it test good... Cdi dorsnt have a test in the manual and I tested primary coil side at .3ohms which is good but I tested the secondary side at 16k which isn't good according to the book but I then tested my buddies perfect running banshee coil and the secondary side has 60kohms which isn't supposed to be correct either so anyone have any ideas. Quote
BeeCanBanshee Posted May 20, 2013 Author Report Posted May 20, 2013 Also the reading on my coil is the same at 16k ohms with no caps on. But I don't get any con. Through the caps them selves. Quote
amado814 Posted May 22, 2013 Report Posted May 22, 2013 I've always heard cdi s referred to as magic boxes . No tests to verify , only real way to test is to swap magic boxes with a known running one . I'm sure other members mightve heard something else. Quote
J-Madd Posted May 22, 2013 Report Posted May 22, 2013 Try another CDI. No way to test them. Have you checked for spark? Quote
BeeCanBanshee Posted May 22, 2013 Author Report Posted May 22, 2013 Yea checked everything is all good now I had a bad ground fixed it and it runs again. Quote
