tdod101 Posted May 18, 2013 Report Posted May 18, 2013 Ill take a complete rear axle assembly with the rear carrier if no one wants to sell just the carrier. Quote
tdod101 Posted May 18, 2013 Author Report Posted May 18, 2013 What ALL exactly do you need? Well I for sure need a new rear carrier, mines fucked. If someone wants to sell the whole assembly I'm willing to buy it, ALSO I can't figure out how to get the carrier off, got the castle nuts and sprocket off today but could t figure out the rest. Basically I need a whole new rear end. Quote
SAVAGE420 Posted May 19, 2013 Report Posted May 19, 2013 Why is yours fuct? Post a pic. The carrier is held on by 2 bolts/nuts, one upper and one lower. No castle nuts there, just 2 nuts and bolts. Simply undo the nuts and slide out bolts. Or can you not get the axle out? It comes out towards the brake hub. I'll pm you a vid if you can't figure it out..... So you need a swingarm, carrier, axle, all the hardware? I have the swingarm and carrier if thats all you need. Think i have the hardware as well. Quote
tdod101 Posted May 19, 2013 Author Report Posted May 19, 2013 Why is yours fuct? Post a pic. The carrier is held on by 2 bolts/nuts, one upper and one lower. No castle nuts there, just 2 nuts and bolts. Simply undo the nuts and slide out bolts. Or can you not get the axle out? It comes out towards the brake hub. I'll pm you a vid if you can't figure it out..... So you need a swingarm, carrier, axle, all the hardware? I have the swingarm and carrier if thats all you need. Think i have the hardware as well. I will PM you Quote
yoder Posted May 20, 2013 Report Posted May 20, 2013 I have axle and carrier, no hubs but the carrier has good bearings in it Quote
