erickson483 Posted May 13, 2013 Report Posted May 13, 2013 So this is not for a banshee, but a cr125. The trans is essentially the same and you guys always have great info. So here goes: I replaced a bent shift fork for 2nd gear in the trans, put it all together and bench tested it. It shifts through all the grears when parked. However, when I ride it doesn't go into 2nd unless I am rippin pretty good in the RPMs. Do you think drum? Gears? Both lol? Any input would be greatly appreciated. Quote
erickson483 Posted May 13, 2013 Author Report Posted May 13, 2013 Forgot to mention. It shifts from 3rd to 2nd fine, just 1st to 2nd is the issue. Quote
camatv Posted May 13, 2013 Report Posted May 13, 2013 something else wrong. is all the washers and clips on the trans? both gears that 2nd engages have nice dog edges? clutch adjusted right? bottom end oil good? shaft fork rides on not bent or damaged? Quote
