Sometimes when I first start my banshee up I'll pull in the clutch and put it in gear and it will just pop into gear and die like the clutch isnt working. Sometimes it will do it a couple times then work fine.... just changed my trans oil it didn't help any.
I've adjusted it on the handle bars and it hasn't helped any. So you think my clutch is worn out? I don't think its slipping I run real close with my buddys kx250.
On the pressure plate there is a screw that is for adjustment of the clutch actuator shaft you wanna make sure it is adjusted properly and inspect the clutch discs while you are at it. With the shaft activator arm on the cases line up the two arrows screw the adjustment screw in till it touches then back off a cunt hair. Could just be cold thick gear oil but for me it was a worn clutch replaced and the problem went away. The adjustment on your handlebars is for cable slack. You wanna tighten that until you can move your bars side to side without seeing any movement in the actuator arm on the case.
