My mods: fresh build, 7mil crank, 68.5 bore with wsm pistons in stock ported cylinders, billet head from white knuckle racing, billet impeller, all shift mods, clutch lock up with straight cut gears, a/m chinsese(cheap)radiator running straight engine ice. Fuel = 110 mixed 40:1 with Torco oil.
Engine is heating up after about 15 min of riding(above 200), mainly when putting around or when there is no air flow.  Runs cool charging up a hill but will heat up when going slower.  Jetting is correct.  (Had it heat up running rich too)  Checked head bolts they are torqued correct. Have no leaks and have done a leak down test.  Not sure where to go from here, have thought about trying the oem radiator? or a different head?  anybody ever have an air pocket in the cooling system?  Too heavy of mods for stock cylinders?
I have had many bikes prior to this not heat up as this one does, granted this is the most hp i have ever run, but it just doesn't seam right. After doing a couple hill climbs i have coolant coming out of the overflow before i get back to camp.
Your pilot jetting is too lean. List your carbs and jets.
wow 68.5 on stock cyls.?! I thought 66mm was pushing stock cyls...Is there any sleeve left? You won't get very efficient cooling with cyls that thin... You should Cub it...
