chere Posted April 7, 2013 Report Posted April 7, 2013 28 pwk carbs with cable and clear bowls i never used... 225 shipped 4mil longrod crank.. needs to be trued.. Journals have spun.. 150 shipped.. 66mm trail ported cylinders... 150 shippedYFZ450 brakes with pads... direct bolt on for banshees great upgrade... 75 shippedRear banshee shock with nuts & bolts, dogbone, and linkage.. 75 shipped Quote
mitchdog Posted April 7, 2013 Report Posted April 7, 2013 How much would it cost to get the crank fixed Quote
chere Posted April 7, 2013 Author Report Posted April 7, 2013 i dont know.. you will have to contact a build Quote
mitchdog Posted April 7, 2013 Report Posted April 7, 2013 How bout those cylinders do they need any work Quote
chere Posted April 7, 2013 Author Report Posted April 7, 2013 they are not scarred but i would bore them to next size.. as pistons are not tight in the cylinders.. Quote
chere Posted April 7, 2013 Author Report Posted April 7, 2013 Just my opinion.. but bike was running fine when taken apart... Quote
bluepartsman Posted April 20, 2013 Report Posted April 20, 2013 I am interested in the calipers. do you have a set of dust shields you could throw in? Quote
