41.3 lectrons. Set up on alky... Ordered new billet bowels and when I turn the gas on it'll run out the power jets and out of the needle.....put stock bowels on and doesn't do it. New seats. New floats set properly I don't get it. And only one does it.... Thoughts?
Be careful not to hydrolock the motor after a sticking float. Sounds like something in the new bowl is binding the float. Maybe swap bowls and see if the problem follows the bowl.
