Selling EVERYTHING!
Ok, so some things came up and it looks like I will not be able to see this project through, super bummed.  I don't know the value of all this so I am going to start out high and say $3500 takes everything, shipping is on you. I might be into a trade, so what do you have?  I have a truck and might be willing to deliver within 100 miles for another $75.  I did get some nice stuff together and the bike is almost completely tore down. It would have been a really nice 4 mil!
So here is what I have:  CT dune ported cylinders (have heli coil repair) with namura pistons.  I also have some stock cylinders that will need a bore.  I have two cases, one set is stock with chain whack and one set is super nice with no chain whack, trenched and clean!  I have two cranks, one is stock and one is a Hot Rods 4 mil with 115mm rods in super nice condition. I have a brand new CFM aluminum air box with 2 never used outerwears. 2 stock carbs with TORS, was going to do the conversion and the throttle cable was broke so that is cut. I have two transmissions, two clutch set ups (one set of stock springs and one set of HD springs) pretty much two of everything you would need for a bottom end. It has the stock suspension on it, the rear shock feels like it was set up for flat racing, BUT I have a set of YFZ stock external res shocks that were revalved with gold valves. The frame is a 90's J arm, with a stock rear end.  The front end has D arms on it but the ball joints will need replaced. Rear axle is an aftermarket axle with adjustable width. I don't have a title. I will give you ALL the parts I have for this. The nerfs are DG alloy series. The plastics aren't a great color scheme but there are no cracks in them, the black and red rear set on the ground is for a 250r but you can have that too!
Let me know what you think its worth, I know its not all great stuff but if you just want to bash my shit, don't waste your time, I won't respond to it.  If you are seriously interested please feel free to text me with your offer, name is Chris, number is 712-899-6473.  I live in Sioux City, IA if that helps..as we say in the chopper world, this is definitely a basic case project.
  • Like 1
does 3500 include the other quad?
No, the quad in the background is my buddies.  I said 3500 as a starting point.  Like I said, please feel free to text me an offer, I know what I have into the parts I bought (the good cases, hot rods crank, etc..) But I am not to sure on the value of the rest of it.. Text the offer to 17128996473
Trenched for 10 mil?
Honestly I could say what they were trenched for, I just have to go off of what the guy before me said, and all he said was they were trenched...but I was building a 4 mil and these are the cases that I got with the crank, all from the same dude.
Is their two trenches cut in the case where the crank sits? The trench would be right under where the rod would be in the center of each hole. 4mils don't have to be trenched so I wonder if the other owner was blowing smoke up your ass. Post another pic of the cases closer or pic a larger pic,
