burgard stem 24 1/4 long in graet shape bar clamp.80
i believe thesew are reathal cr bend long horn bars, there 1 1/8 in the middle and 7/8 on the ends so your stock levers,throddle will fit. tough bars, 30 , twist throddle with reathal grips and cable,cable looks sketchy but may work?18 .looks to be a yfz 450 front brake rezzie with lever,perch.if you have the front 450 calipers this is a must have imo.25 unsure of maker clutch perch &lever 11 . more to come
