I got a set of ten mil cases that were trenched for a 10 mil 115 rod. I have a ten mil 120 rod crank that ill be using. When I went to drop the crank in it was rubbing the case. Just the connecting rod. The 120 rods have a bigger pin then the 115. So has anyone out there ran a ten mil with 120 rods that can tell me if they had to epoxy the cases or not?
Yes you will, big pin crank has to be trenched more.
