Well here's the pics from my tear down. Not too bad. Was definitely lean though like I figured. Here's right before I took her apart,
Got the intake off and the left side was definitely messed up. Not sure why?
Head gasket was pretty much toast. All warped and not much of the rubber left on the metal part of it. Had water in my pipe and this seems to explain it
The right side was the bad side. Not horrible though. Piston melted to the head a little and a tiny tiny bit on the cylinder wall at the very top that I think can be bored out fine. No scores
The piston definitely was hot though. Right side is the first pic left is the second
Once the cylinders were off I noticed on a transfer port that the aluminum from the cylinder wasnt tight to the actual cylinder wall. Not sure if that will hurt anything. I think it was like this but not sure. Hopefully is shows ok in the pic
That's pretty much it. I'll post pics of the rebuild when I get parts. Might be a while
