I finally got around to mounting my asv levers and have lost the instructions. When mounting the front brake lever to the oem front master cylinder do you use the small spring that goes between the master and the lever? The oem lever has a pocket for the spring to fit into, the ASV lever doesn't and the spring lays over on the plunger boot..
Do I use the spring, don't use the spring, or cut the spring down?
Thanks in advance.. It 's going on a 2000 Banshee..
Shouldn't need it. I have both ASV C3 levers for a few years, all good!
