I'm really paranoid after my build, just to warn you all. Here are my plugs after she warmed up about 3 or 4 times and then driven for about 2 min in 2nd gear. What do you think? The left plug came from the left side and the right came from the right.
your air screws should be somewhere around 1 to 1.5 turns out try bigger jets
I should have specified. I'm at 1.5 turns out, 27.5 pilots middle clip on the needle, 800ft elevation, 80 degrees, no lid, 310 on the main but will be going down after if chops. No motor mods, just pipes and reeds really
Edited by erickson483
