bansheeboi Posted May 20, 2012 Report Posted May 20, 2012 The is the setup t5's cascade silencer stock carbs 300 mains not sure on pilots uni pod filter. Okay bike will only run idle when choke is pulled out, I push choke in an bike act like its leaning out and shuts off. Also if choke is push in bike will not start. What do I need to do guys to get this thing to idle its me ole lady bike an she ready to ride, and race. Quote
armyvet Posted May 29, 2012 Report Posted May 29, 2012 The is the setup t5's cascade silencer stock carbs 300 mains not sure on pilots uni pod filter. Okay bike will only run idle when choke is pulled out, I push choke in an bike act like its leaning out and shuts off. Also if choke is push in bike will not start. What do I need to do guys to get this thing to idle its me ole lady bike an she ready to ride, and race. if it only idles with choke thats a dead give away ur lean on the pilot....usually.but banshees can be strange animals sometimes.make sure that crossover tube is in place between the 2 carbs and not cracked.check for air leaks in carb boots etc. Quote
bansheeboi Posted May 29, 2012 Author Report Posted May 29, 2012 if it only idles with choke thats a dead give away ur lean on the pilot....usually.but banshees can be strange animals sometimes.make sure that crossover tube is in place between the 2 carbs and not cracked.check for air leaks in carb boots etc. now its boggs like hell then clears up an ripes but sometime it will start with or without the choke Quote
armyvet Posted May 29, 2012 Report Posted May 29, 2012 could be rich on the main.make sure you do 1 thing at a time.if you go changing things for the sake of changing or just stabbing in the dark you can spend forever chasing your tail.I had a banshee with the single carb set up do thae bog then hit like a ton of bricks.tried needles and clips positions and finally it seemed like i was back to jetting i already tried previously and it was fine ever since...go figure.If you arent prepared to tinker you cant own a banshee and mod it Quote
