willardwright59 Posted April 10, 2012 Report Posted April 10, 2012 i bought a 1999 yamaha banshee here is the modification list; MOTOR 392cc athena kit 19cc domes +4 timing Vf3 reeds 28mm carbs water pump impellar pro circuit pipes (cut silencers) SUSPENSION stock shocks front wheel spacers +2 rear axle +4 extension on stock swingarm BODY (looks) stainless bolts custom visible clutch cover PC yellow frame Yellow fuel lines and vent lines Pro elite front bumper twist throttle 22 inch rear tires +more im forgetting the bike currently does not run, it needs a coil. buddys moving to the city, dont have room for a trail quad. total price is $3600. SPARE PARTS 64.50 trail ported cylinders wiseco piston kit for cylinders trinity coolhead 20cc domes ported cases k&n pro flow filter port matched cases beadlock rims D.I.D gold chain Fat bars anti-vibration steering stem 13t-17t front sprockets 38t-42t rear sprockets yfz450 brakes all are "spare parts" because they are not on the bike yet, most will go on but some will be sold. bike does ripp when i throw my stock coil on it. questions: athena 392cc kit, who has ran these on trails? what size carbs would benifit this current set up? this being a hardcore trail/dirt road race bike, what gearing would make it faster than others? alot of work is going to be put into this bike. im just needing some help from the pro's while im setting this up. Quote
willardwright59 Posted April 10, 2012 Author Report Posted April 10, 2012 You paid $3600 for a bike that doesnt run........ i just went and got it a little while ago. it runs with my coil. i payed 1500$ down, i gave him a check for 800$ and he took that.so $2200 Quote
wfobasheeboy Posted April 10, 2012 Report Posted April 10, 2012 Sound good for 2,300. Post up so pick to see this ride. Quote
shakar Posted April 10, 2012 Report Posted April 10, 2012 Sound good for 2,300. Post up so pick to see this ride. +2 on pic's....... i want to check out the ''custom visible clutch cover'' Quote
So Cal Suspension Posted April 10, 2012 Report Posted April 10, 2012 this being a hardcore trail/dirt road race bike, what gearing would make it faster than others? Do yourself a favor, before you do ANYTHING regarding the motor, or further modifying the motor: Get those wheel spacers out of there, and get that swingarm off the bike before you kill yourself. Spend the money on aftermarket a-arms and shocks, and a QUALITY swingarm, not some hack job. Quote
willardwright59 Posted April 10, 2012 Author Report Posted April 10, 2012 Do yourself a favor, before you do ANYTHING regarding the motor, or further modifying the motor: Get those wheel spacers out of there, and get that swingarm off the bike before you kill yourself. Spend the money on aftermarket a-arms and shocks, and a QUALITY swingarm, not some hack job. agreed! this thing is coming clear apart and put together with all new seals and bearings all over the bike. i will be posting pics to a photobucket account as soon as i get a chance to upload them. let the tear down begin!!! Quote
eldreder Posted April 10, 2012 Report Posted April 10, 2012 http://www.bansheehq.com/forums/index.php?/topic/151926-willardwright59 Quote
willardwright59 Posted April 10, 2012 Author Report Posted April 10, 2012 http://www.bansheehq...willardwright59 ummm? whats the link u posted? it didnt do anything at all..... took me to the home page :confused: Quote
willardwright59 Posted April 10, 2012 Author Report Posted April 10, 2012 +2 on pic's....... i want to check out the ''custom visible clutch cover'' step by step directions on how to do it 1. cut out the center under the clutch cover insert 2. use o-ring from stock insert to mark holes onto lexan or fiberglass 3. drill holes and bolt in spot of insert. thats what he told me... i asked if it had a lock up..... nope Quote
