Put some 34mm carbs on my bike and it does run right on the buttom in it does start pulling and till you start geting up in the gear could it be a jetting problem
Where about? 1/2-3/4,3/4-wot? What's your mods? What's your jetting now? What's your elevation? What's the temperature? Have you done a plug chop yet?
With all this info, some one can prob get you about spot on.
I have a 4 mill long rod with 20cc dome with a dune port job with boost ports and my jetting is 300 main and my elevation is 203ft temperature is 70 no i havent done a plug chop yet and 1 and 2 does feel the powerband
