ive got 55 WATS driving lights kit but before i instal it i wanna know is that too much of draw for stock banshee?
Yes, Your stock stator can handle ~75 watts on the lighting circuit, MAX... typically that means two 35w headlights, and a 5-10w tail light.
tnx,so i have to get better stator or to instal baterry?
Not a battery, but you will have to upgrade your stator. Unfortunately, 99% of the aftermarket stators on the market are complete junk, and often don't work right out of the box. You'd be better off leaving your stock stator, and upgrade your lights.
I sell 10w LED lights. All you will need to do is a DC Conversion. No battery is needed. The lights are $198 for a pair, shipped. They are 950 MEASURED lumens each. Nearly 3x as bright as your stock lights, and only draw 10 watts of power each. PM me if you want more info.
  • 2 weeks later...
hov can i do dc conversion,is it from 12V to 5V?
Contact matt he has all the info you need and will be doing a step by step install/conversion with his lights.
