What is your elevation and what pipes? I would say stock needles and 27.5 pilot.
well the internet says im at 4436 feet and fmf gold i think its a midrange pipe vs the fatty or toomys. cool so im going to keep my needles and change the pilot. mains i will start with 290 and go from there and I run the clip second from the top its my sons machine im buliding. its stock and the shees i have ownd allways ran 34 35.5 not used to the stock carbs.
Edited by sandman125
Im not exactly sure where you want to be at 4400 feet. I would give Jeff a call at FAST and he will get you dialed In and sell you what you need in the process.
Your post says stock pipe??? Is it stock or fmf? If it is a stock pipe stick with a stock pilot if not then you may need a 27.5 but most likely you would be fine with a stock pilot with just pipes and K&N filters and a 290 main at your elevation should be way to big I would guess you are going to be around a 260 on a stock carb.
I thought the same thing, I am assuming he means a stock bike that is piped with pods.
