Hi I am building a drag 350 motor and going to run a pvl I bought and was wondering if anyone on here runs lights with there pvl ignitions?? I know that they dont have the lighting coil in them, but was wondering if anybody has either found some battery powered strong headlights or maybe modified the stator in order to run them?? Any input is appreciated, thanks in advance
from what i know about the pvl, you will need to get a battery to run the headlights. maybe talk to mattscss about his LED lights. trailtech also has some battery powered ones also.
Talk to MattSCSS like Coup said. Matt will point you in a direction of a small battery that would last with some low aH draw lights.
I'll just post in here.
My 10w LED lights draw .86A each. 950 Lumens, and are about 3x as bright as stock lights, or traditional Trail Tech lights, and only about $25 each more. They are $99ea, shipped.
You can get an 18ah SLA battery on eBay for about $40 shipped. The 18ah would run two of my lights for approx. 10 and a half hours on a full charge. For most people, that would be an entire weekend trip. My LED's operate on 9-50v, so you may even get a longer than 10.5 hours run time.
http://www.ebay.com/itm/12V-18Ah-Sealed-Lead-Acid-SLA-AGM-Replacement-Battery-/270913680203?pt=US_Batteries&hash=item3f13b6b34b
  • 2 weeks later...
I sell a 12v lithium ion 6ah battery. It weighs less than 1Lb. It is small enough to fit in the spot under the seat of the banshee where the factory toolbox goes. It also comes with a charger.
