120" Lonestar Chassis
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
anything on this list you need?
DRAG PARTS:
10mm supercub topend (cyl, piston, head w/domes) needs coated soon. $800
poilished cases (no wack) $250
polished Mattoon lockup cover w/waterpump $225
38mm alky mikuni carbs w/billet bowls $400
Kehin 34PJ carbs w/cable $200
DMX cylinder (18mm x 85mm bore) ported but not coated $400
18mm crankworks billet crank (big pin/big wheel 133mm rod) $500
custom painted plastics: candy red w/ghost chains and skulls (front, tank, radiator plastics w/cascade grill) $225
painted red plastics (front, tank, radiator plastics) $50
alum insert $15
billet handlebar clamp $20
chrome v bars $20
STOCK PARTS:
stock tranny $110
sprocket hub $30
brake hub $15
set lower a-arms $65
spindles (old syle) $30set
spindles (new style) $40 set
set tie-rods (w/ends) $30
radiator $20
complete front brake assy (new style) $50
rear brake lever $25
rear shock $60
rear linkage $20
chrome sm & polished rear linkage $60
foot pegs $20
front hubs w/rotors $30
tank $20
rear 10x9 alum wheels $100
stock rear spring $15
stem mount $5
swingarm sleeve $10
rear brake system polished w/billet rez $125
front shocks $50
cases (w/chain break) $125
cases (w/out chain break pc'd shocker yellow) $200
clutch cover $20
  • 2 months later...
  • 6 months later...
  • 1 month later...
