Just picked up 144 inch and a quarter sled studs for the shee. I have a bald set of 20x11 6 ply razors and a set of 19x10 4 ply hole shots for rears. For fronts I have a set of stock bald Honda fronts that are more of a rounded tire they are 22x7x10 or a set of squared fast Trekkers that are 21s. For the rears I'm not sure which size would be better smaller or bigger I'd like to hit the circle track a little bit but more looking for straight line traction out on the ice. My other thought was if a v pattern would be better or more of a straight line pattern would be better to allow some side sliding allowance. My other thought/question for the fronts was to either go with a single line down the middle on the round tire or a staggered pattern on the square ones. I was thinking line 40-50 in each rear and 20-25 in each front, or would I be better of just getting regular screw in sheet metal screw style studs for the fronts
Any answers are appreciated thanks guys
Sled studs are going to suck on a oval, and are "ok" for drag. I run 70 per tire on mine and spin off the line for a little while. I would suggest getting sled chisels instead of regular studs. I would also suggest running one inch kold kutter studs up front. You kinda gotta choose what type of riding your gunna do, I would do two different sets for drag and playing on the tracks.
