From Mild TO Wild! Posted September 30, 2011 Report Share Posted September 30, 2011 (edited) I am in need of the head and piston rings and gasket kit. Ill trade amp straight across for parts or partial trade. Id prefer wiseco and a cometic top end gasket kit. amp specs: STROKER Single-Channel Class GH Car Amplifier RMS Power Rating: 4 ohms: 400 watts x 1 chan. 2 ohms: 750 watts x 1 chan. 1 ohm: 1000 watts x 1 chan. Full PWM power supply Class GH amplifier topology Wired remote bass level control included Power and protection LED indicators Bass Boost: 0-12 dB bass boost at 45 Hz Single-channel monoblock operation 1 Pair of preamp RCA outputs Heavy duty aluminum alloy heatsink for optimal heat dissipation Silver RCA level inputs Silver screw terminals Built-in phase adjustment Input gain adjustment Variable low-pass filter (40-250 Hz, 24 dB/octave) Subsonic Filter CEA-2006 compliant amplifier Frequency response: 20-250 Hz Dimensions: 9-1/4"D x 15-3/4"W x 2-1/4"H 1/0-gauge power and ground wiring Amp works 100% and has few scratches. Here is proof of my online buying selling habbits< http://www.caraudioclassifieds.org/forum/itrader.php?u=7476 I use to trade sell and buy car audio stuff all the time. Now im getting a blown up banshee tomorrow so that hobby is out the door. Thanks guys i appreciate the help and forum and hope to trade with you soon. Tomorrow ill be able to tell you the bore because ill be able to check it with my calipers. Edited September 30, 2011 by From Mild TO Wild! Quote Link to comment Share on other sites More sharing options...
From Mild TO Wild! Posted October 1, 2011 Author Report Share Posted October 1, 2011 (edited) I am in need of the head and piston rings and gasket kit. Ill trade amp straight across for parts or partial trade. Id prefer wiseco and a cometic top end gasket kit. amp specs: STROKER Single-Channel Class GH Car Amplifier RMS Power Rating: 4 ohms: 400 watts x 1 chan. 2 ohms: 750 watts x 1 chan. 1 ohm: 1000 watts x 1 chan. Full PWM power supply Class GH amplifier topology Wired remote bass level control included Power and protection LED indicators Bass Boost: 0-12 dB bass boost at 45 Hz Single-channel monoblock operation 1 Pair of preamp RCA outputs Heavy duty aluminum alloy heatsink for optimal heat dissipation Silver RCA level inputs Silver screw terminals Built-in phase adjustment Input gain adjustment Variable low-pass filter (40-250 Hz, 24 dB/octave) Subsonic Filter CEA-2006 compliant amplifier Frequency response: 20-250 Hz Dimensions: 9-1/4"D x 15-3/4"W x 2-1/4"H 1/0-gauge power and ground wiring Amp works 100% and has few scratches. Here is proof of my online buying selling habbits< http://www.caraudioclassifieds.org/forum/itrader.php?u=7476 I use to trade sell and buy car audio stuff all the time. Now im getting a blown up banshee tomorrow so that hobby is out the door. Thanks guys i appreciate the help and forum and hope to trade with you soon. Tomorrow ill be able to tell you the bore because ill be able to check it with my calipers. I could trade for cosmetic gasket kit and decent head and something else Edited October 1, 2011 by From Mild TO Wild! Quote Link to comment Share on other sites More sharing options...
