What year is the bike? Does it have all the stock wiring components on it that came from that year?
It is a 1988,and the wiring is all stock except for the tors has been eliminated.
There was no parking brake limiter on a 1988, unless you swapped in a newer year harness.
Grounded how?
I am not sure how it was grounded all they said was the box was grounding out and that was causing the problem. So i guess i got to tear in to my banshee and go through it.
check the cont from your coil + to the ground. AND you may have to rip the entire harness out and find that the pipes burnt it in a spot and its a minor ground out. if you plugged in the new box and it doing the same thing may have fried that one too..
dyna's are more sensitive than a stocker. BUT a stocker CDI would surely have an issue if there was a grounding problem.
check the stator also.
