I just found out i am being transferred and since Im not sure if i will be able to pursue my hobby abroad,I am going to lighten my travel load.
I am located in Lorain Ohio
Up for sale is my 2000 Yamaha banshee 421.It received a frame up restoration over the winter.I spared no expense in making this the ultimate trail quad.The frame was painted ford blue and everything else was powder coated black.the chassis received all new bearing and bushings including axle,a-arm and spindle.This is literally a brand new banshee.I set this engine up to run an premium pump gas.The list of modifications are as follows.
421 cc Yamaha banshee enigine
Vitos 68mm ported cylinders with triple exhaust ports
Hot rod 4mill stroker crankshaft with maxload bearings
Wiseco 68mm blaster pistons
Port matched engine cases
Billet clutch basket with Toomey springs
Brand new clutch cable
Boss racing clutch saver throw out bearing
Cascade modified shift star
Pro Design cool head with 18cc 9 degree blaster domes (comes with 20's too)
CPI racing exhaust pipes
V-Force 3 reed cages
Keihn 34.5mm carbs
Pro-Flow K&N filter with K&N filter Lid
Adjustable timing plate +4 degrees
Billet water pump impeller
TM design case saver
Billet 3 pc Stator cover
Polished clutch cover with inserts
+2 A-Arms with kevlar injected heims
Works Dual rate shocks with rezzy and ball bearing bushings.
Yfz 450 dual piston front calipers
Stainless brakelines front and rear
Denton steering stabilzer
Fast FLEXX handlebars with pro taper pillow top lite grips
Tether kill switch
Alba custom Graffix
Graydon Pro line aluminum nerf bars
Pro line hand guards
Pro armor front and rear aluminum bumper
Hiper racing carbon fiber wheels 22/7/10 kenda klaw 20/11/10 Maxxis Razr rear tires (3 rides)
The quad was dynoed and carbs tuned after the initial break in.This engine made just shy of 80 hp and 43 ft lbs of torque.This engine will make alot more with pod filters,higher compression and Shearer inframe racing pipes.Since I used this atv for recreation , I opted for the reliability and pump gas over maximum hp/race fuel.If your looking for more hp,there is still some hiding there.I have ridden this banshee 3 times this year on trails and that is it.Its literally a completely brand new machine.
The selling price is $3500 If this does not sell in 30 days,I will be parting it on craigs list and ebay..I have lots of pictures,I can send via email.It is available for viewing after 8pm mon-fri.after 6pm on weekends.PM me and I will get back to you ASAP
Edited by bigborebanshee
Damn brian sorry to hear you have to get rid of your shee. And yes I do regret parting out my last one. If I find anyone looking for one down here I will show them this one. Let me know if you are going to part it I would be interested in your carbs.
I bought a banshee off this guy a few years ago. Good guy to deal with.
Thanks Kodie,i will def let you know if Im parting it.We had good transactions in the past :cheers:
I really hate to part it though,I spent 6 months building it over the winter/spring.Hopefully someone is looking for a nice built banshee.
Where you getting transferred to? There no way to keep it?
Good looking bike man, that blows you have to get rid of it. I'm sure it took more than $3500 to do complete the rebuild though. If you don't mind me asking, who makes that stator cover? I like it! Good luck with the sale
Kodie,Im going to be working as a consultant/process improvement for a manufacturing company in Asia.I will spending most of my time between China and Taiwan for the next year.Since I am single and have no ties here. I will look for opportunities abroad,don't know where i will land yet
Fullthrottle,i bought the stator cover new off ebay. I think i paid 170 bucks
