ronl1967 Posted June 14, 2011 Report Posted June 14, 2011 (edited) ENGINE BUILT BY KIM MUCHMORE! IT IS A PORTED CUB 7MM WITH BLASTER PISTONS ON ALCOHOL, KIM ESTIMATED OVER 120HP. LAST TIME I SENT IT IN TO KIM, I SPENT $2200.00 FOR CUB, CRANK REBUILD, TZ BEARINGS, PISTONS, DOMES AND SEALS. RAN IT MAYBE A HALF DOZEN TIMES IN SAHARA SINCE THEN. FRAME CUSTOM BUILT, 4" IN FRONT AND VERY LIGHT, NEEDS PAINT TOUCH UP OR POWDER COAT. PLASTIC IS CUSTOM CUT AND PAINTED BY RED HOUSE CUSTOMS IN DERBY KANSAS, DOES HAVE SOME SCRATCHES AND CHIPS, BUT STILL VERY IMPRESSIVE!! ASKING $6200.00 FOR ALL LSR 10" OVER ALUMINUM SWING ARM JJ&J ALUMINUM AXLE ALUMINUM CARRIER 22X11X8 SLS 12 OADDLE HAULER (still like new) SMOOTH FRONT CUSTOM 4" IN FRONT LIGHTNED FRAME CUSTOM PLASTIC WITH AIR BRUSH DRAGON CUSTOM CUT SEAT CUSTOM EXTENDED STEERING STEM CUSTOM DRAG HANDLE BARS 38MM KEIHN ALCOHOL CARBS, WITH BILLET OVERSIZE BOWLS, SET UP BY ROB AT RDZ OVERSIZE K&N FILTERS OVER-RIDE TRANNY LOCK-UP CLUTCH LIGHTNED FLYWHEEL CUT STATOR PORTED REED CAGE BILLET INTAKE BILLET PEGS BILLET STATOR COVER BILLET CLUTCH COVER BILLET K&T COOL HEAD BILLET KICK START BILLET GEAR SLAMMER PINGLE VALVE MARVIN SHAW SHOCKS <!--~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~--> Edited June 14, 2011 by ronl1967 Quote
wizeass2005 Posted June 14, 2011 Report Posted June 14, 2011 im broke like everyone else but i wanna see pics. Quote
ronl1967 Posted June 14, 2011 Author Report Posted June 14, 2011 (edited) im broke like everyone else but i wanna see pics. this should help, thanks http://i986.photobucket.com/albums/ae348/ronl1967/103_6842640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6841640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6839640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6818640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6821640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6822640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6823640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6824640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6825640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6838640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6830640x480.jpg Edited June 14, 2011 by ronl1967 Quote
ronl1967 Posted June 14, 2011 Author Report Posted June 14, 2011 ENGINE BUILT BY KIM MUCHMORE! IT IS A PORTED CUB 7MM WITH BLASTER PISTONS ON ALCOHOL, KIM ESTIMATED OVER 120HP. LAST TIME I SENT IT IN TO KIM, I SPENT $2200.00 FOR CUB, CRANK REBUILD, TZ BEARINGS, PISTONS, DOMES AND SEALS. RAN IT MAYBE A HALF DOZEN TIMES IN SAHARA SINCE THEN. FRAME CUSTOM BUILT, 4" IN FRONT AND VERY LIGHT, NEEDS PAINT TOUCH UP OR POWDER COAT. PLASTIC IS CUSTOM CUT AND PAINTED BY RED HOUSE CUSTOMS IN DERBY KANSAS, DOES HAVE SOME SCRATCHES AND CHIPS, BUT STILL VERY IMPRESSIVE!! ASKING $6200.00 FOR ALL LSR 10" OVER ALUMINUM SWING ARM JJ&J ALUMINUM AXLE ALUMINUM CARRIER 22X11X8 SLS 12 OADDLE HAULER (still like new) SMOOTH FRONT CUSTOM 4" IN FRONT LIGHTNED FRAME CUSTOM PLASTIC WITH AIR BRUSH DRAGON CUSTOM CUT SEAT CUSTOM EXTENDED STEERING STEM CUSTOM DRAG HANDLE BARS 38MM KEIHN ALCOHOL CARBS, WITH BILLET OVERSIZE BOWLS, SET UP BY ROB AT RDZ OVERSIZE K&N FILTERS OVER-RIDE TRANNY LOCK-UP CLUTCH LIGHTNED FLYWHEEL CUT STATOR PORTED REED CAGE BILLET INTAKE BILLET PEGS BILLET STATOR COVER BILLET CLUTCH COVER BILLET K&T COOL HEAD BILLET KICK START BILLET GEAR SLAMMER PINGLE VALVE MARVIN SHAW SHOCKS <!--~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~--> http://i986.photobucket.com/albums/ae348/ronl1967/103_6842640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6841640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6839640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6818640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6821640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6822640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6823640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6824640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6825640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6838640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6830640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6846640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6844640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6829640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6828640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6827640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6837640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6833640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6834640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6848640x480.jpg http://i986.photobucket.com/albums/ae348/ronl1967/103_6847640x480.jpg Quote
4MiLLDraGSheE Posted June 14, 2011 Report Posted June 14, 2011 If you decide ever to part it i got dibs on the haulers Quote
2stroke in my blood Posted June 14, 2011 Report Posted June 14, 2011 and id be keen on the complete motor at the right price! Quote
ronl1967 Posted June 14, 2011 Author Report Posted June 14, 2011 and id be keen on the complete motor at the right price! What would be the right price? Quote
