I have a question about my banshee because I've been having problems with. My banshee didn't have spark but I found out that when I press down on the throttle to where it makes a click, I get spark. I took apart the throttle and saw that when the two metals end aren't touching, it works. What's going on here?
check the carb slides one maybe stuck, the tors is working. if the slides are both going all the way down to bottom, disconnect the tors box, should have spark then.
