hey guys i'm getting ready for the season so i put my banshee back together, and when i have it idling it will rev on its own and when i ride it around it feels like the gas throttle gets stuck and will rev on its own. any ideas?
im running an 03 banshee and i've had a 350 drag port job and i have pretty much all the work to it: cpi's, coolhead, v force reeds, 34 mikunis etc... i've cleaned them out twice now, all the way down to the bowls with carb cleaner. and i don't seem to see or hear any leaks
You won't hear or see the air leaks. You'll need to do a leak down test to find them.
Need to look up on here about making yourself a leak down kit. Very cheap (pvc pipe)
Pressurize to a max of 6 psi, wait an hour or so, if standing test proves to show a lower psi....you have a leak. Spray some soapy bubbles if so, and it will tell u where if really small.
A lazy way is to spray some carb start lightly around your intake area and engine as it idles. If it revs up, u have a leak.
