i have a 2004 banshee and the canecting rod bearing on the crank let go on me to different times now, any ideas on the cause?
Was the crank welded? Do you store the bike where it is dry or does it sit out in the rain? What oil do you run and at what mix? Do you do any maintenence or do you abuse it? Bottom line is we need more info to help you.
