malcman Posted May 24, 2011 Report Share Posted May 24, 2011 Just wondering if anyone knows if the water pump impeller bearing is suppost to sit flush in the clutch cover or if the bearing should sit up a little bit? Thanks Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted May 24, 2011 Report Share Posted May 24, 2011 i use a socket and press the seal in(oil the outside if the seal), then oil the bearing and press that in, till it stops. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted May 24, 2011 Report Share Posted May 24, 2011 Agreed. I always coat the bearing with grease and pack both lips on the seal with grease. Be careful to not pop the lil mini springs off. Coat the impeller shaft and the big o-ring as well. Quote Link to comment Share on other sites More sharing options...
malcman Posted May 24, 2011 Author Report Share Posted May 24, 2011 Thats my plan for sure, the socket seems to work well. when I removed the old one it was sitting a little bit above the case so I wasn't sure if this was normal or not. The seal seems pretty fragile so I didnt want to press too hard on it Thanks fellas Quote Link to comment Share on other sites More sharing options...
06specialedition Posted May 25, 2011 Report Share Posted May 25, 2011 I didn't coat my impeller shaft....ooops Quote Link to comment Share on other sites More sharing options...
camatv Posted May 25, 2011 Report Share Posted May 25, 2011 it will be fine.. a friend of mine made me a bad ass installer for the seals and the bearing it fits in t eh cover the seal pops in the holder and you just ease it in there by hand everything lines up so nicely its installed by hand. Quote Link to comment Share on other sites More sharing options...
